Sorry for not being complete as for the info.
We had 355 gears but due low tires it gave to many revs so wanted to change to 2.94's. We know the shim thing as in trial & error but how do I explain...
Whichever shims we use the pattern 'wobbles' around like if the ring gear is bent or the r&p doesn't match. Hope you catc what I mean
