... I've always heard gas stations get their midgrade gas, by pulling from the lower and higher grade gas tanks. Don't know that for sure, but if so you could probably find a place that sells high octane race gas and buy a couple of gallons to mix in with what you have.
That sounds like a big 'wives tale' story.
Gas is very regulated and monitored. No way of blending high and low octane at the pump.
Incorrect. Mixing the two is exactly how mid-grade is concocted.
Are you saying it's concocted/blended right at/in the gas pump at the gas station itself?
Or before it's delivered to the station?
