Mine is a 4.31 bore x 4.25 stroke which is a 4.96. The only drawback of the small bore size so far is we had to machine an eyebrow at the top of the cylinder for the larger than stock 2.300 intake valve.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
