Looks like an article full of helpful info. Out of curiosity, did you consider using Mopar's small block casting? It has siamese bores and can easily deliver 440 cubes without too much hassle.
Was cost the main factor? I know the block ain't cheap but you might have made up for it by saving on machining expense.
