Will the large bolt pattern fit my car, a 66 B'Cuda. The price sounds right at 250. There are spindles, calipers and rotors.
You will also need 73-76 A-body upper control arms as the large bolt spindles use the larger ball joint. I would check and see if those are included too for that price.
