Re: TIMING QUESTION
[Re: hemi-itis]
#1351820
12/20/12 01:14 AM
12/20/12 01:14 AM
Posts: 369 California, USA!!!
WheelsUp73
California, USA!!!
BTW,,,,,,,the straps were in the oil pan
ok...now i see, you ned to really strain the oil to keep the straps out of the bearing area...
Exception to the rule is when said strap enters through the top of piston.I thing they evaporate similar to a meteorite entering the atmosphere.So you would really have to sift through all the remnants in the oil pan
Detonating that bad makes for extreme cylinder temps. The straps melted away like solder.
