Start off at 50-60 total. Then as you replace parts retard it little by little till you hit the sweet spot. A good rule of thumb if you are replacing big parts retard it more, if small parts less. Good luck with it!!!
If you have any problems there is a guy up in your neck of the woods that uses this methods. I am sure he would be glad to help you out. Lol
Getting old just means you were smarter than some and luckier than others.
