Re: Tremec 5 Speed
[Re: roadrunner7020]
#1349438
12/11/12 12:06 PM
12/11/12 12:06 PM
Posts: 18,160 Mass
DAYCLONA
Mass
I can't speak for a e body but after putting one in a b body I'd wait on Jamie's transmission. I'm fairly happy with mine but for what I spent to make it that way of his transmission would've been on the market that's the route I would've took.
I don't know what costs you inccurred on your B body install, the Passon 5 spd is $4200 that's just the tranny, you supply everything else,...My Keisler B body TKO 600 .64 OD 5spd set up was $4500, that's transmission, bellhousing and cover, SFI flywheel, Sachs BorgBeck pressure plate, Sachs Kelvar clutch, hyd throw out bearing/master, repro pistol grip shifter and shifter boot, crossmember, and mount, and a balanced 10,000 RPM new driveshaft and joints, speedocable, and assorted hardware,...The last kit I did came in at $4300 complete as mentioned above
Mike
