Obiviously you missed the thread by a few days, go read "Shaker sitting low" thread in the Restorarion section should you want to run a Tremec from some of the various vendors....Should you decide Passon is your cup of tea, the final OD ratio is .70
Tremec OD is available from .82 .68 and .64...1 thru 4 gear spreds have two option
Mike
