When I started working on this Duster, I was told it was an old ProStock, but I doubted it. The Pro on the window did not convince me.
However, the old S&W roll cage sticker does give a little credence to a possible ProStock history. Has aftermarket front sub frame with coil-over suspension w/rack, a 426 Hemi, and a Dana.
Anything is possible I guess. The seat belts were dated 1988, so it hasn't seen much action recently, and only 4 passes this year after I got it updated enough to pass tech.
