Quote: I have a bit of an odd ball combination but it is a low deck deal based on a 383 so I thought it would still fit the thread. 4.280 bore with a short piston , small dome netting approx 11:1 compression. 6.860 MP lightweight Oliver rods , lightened stock crank with a slight decrease in stroke to 3.360" . MP Stage 6 heads with a small port ,MP 2.14 , 1.81 valves (3/8" stem) , MP 590 solid camshaft, Edelbrock victor 440 manifold with .080 cut off each side to fit the heads properly and a old carb shop 850 carb. This deal is 385 cid and seems to like shifting around 7800 rpm. Its in a 3100 lb car and has run a best of 9.86 at 135.60 in good air through header mufflers. Many don't believe its basically a 383 but thats fine. Its very mild , behaves well and has proven to be a great bracket motor for the past 5 years. I have another one of these im going to start pieceing together but I will increase the stroke to 3.600 as the small motor is lacking slightly in the torque department.
Hutch
Please post the video clip of your car again. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
