i need to change out the lower tie bar, i have a good one from another donor, and use my orig upper tie bar so my so number matches the trunk lip, even tho that will have to be grafted into whatever i use in the back whether its or steel or amd. I have found out its alot harder to find the spot welds on rusty metal...the air chisel has come in handy too! all for now, maybe some more tomorrow evening.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
