dug into it some this weekend, finished gutting it...then I removed about 200 self tapping screws to remove the patches in the floor. galvanized roof flashing is a good substitute isnt it? cut out the front floor behind the t bar crossmember, then removed the front stub. oddly enough the t bar x member is really solid, to bad the frame rails arent. the pass is ok drivers is trashed...
