I had a 86 Ram/C.Nice truck.It did not have anything on the air cleaner,just the control unit by the battery.Only thing I did to mine was get a carb for a 1969 318.That made a difference.
I wasn't sure if it should have had the lean burn but I figured being an 86 it should have an ECU and Ballast resistor but it doesn't. No vacuum advance on the distributor either.
