I'm going to undercoat my rear wheelwells this weekend and could use any tips you guys may have. The directions are good an say to use light coats. How long to dry between coats? I'm using a 3M 8997 Shutz gun and pressure wll be set per the directions. I'm trying to get as close to factory appearing as possible so any tips, tricks, or advice would be greatly appreciated.
