Quote: Thanks for the input guys; my question is if you think the pump has failed then why do I have good fluid flow to the trans cooler?
See my comment above, "even with the drive tangs broken there can be enough friction between the pump rotor and drive hub to create some pressure but not enough to engage a clutch."
