2. AndyF had the best results using the MP .528 cam with HP manifolds. Assuming the cam events were the factors resulting in success, would it make sense to have a custom cam ground using those same events but with higher lift? Much work has been done on optimizing cam lobes since the .528 was designed.
R.
might be easier to use 1.6-1.7 ratio rockers, or find a similar .050 duration roller lobe, which will have a lot more lift...
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
