You might want to think that over carefully..
https://board.moparts.org/ubbthreads/show...rue#Post7384092
This was a 318/390..
Chris..
Unfortunately when a part fails like this it takes out the whole enchilada. This has nothing to do with the 318/390 build at all. I had the same thing happen to a hot 340 I had at 7200 RPM, Was not quite as bad but it did drop a valve, took out a cylinder, broke a pistion fkd up the head, annihilated a Rod. I could only find balled up pieces in the pan and all over the inside of the engine, intake etc. This can happen to any engine when a Valve lets go. I put a 410 Stroker in it and when I fired it off I had quite a few pieces come flying out the exhaust that were stuck in the mufflers.
