Here ya go,Frankie. Note that the tool(I use a 1" coupling nut and machine screw) is only a helper."Tighten tool enough to place ball joint stud under pressure then strike steering knuckle arm with a ". When one is removed the tool goes against the knuckle. I much prefer this method to beating the crap out of the knuckle and it's a lot easier.
