I found the front band adjustment to be at 2-7/8 turns out from 72"/lbs (just shy of 3 turns out). I then reset it to 1-3/4 turns out from 72"/lbs.
I put in a new band from A&A six years ago when I made the last band adjustment (2-1/2 turns out). I also put in new clutches about two years prior to that.
1970 YO7 A66 [Canadian Export] F8 Challenger
340 (Currently in shop for stroker assy.)
