Another interesting detail, of course not worthy of replication would be a slight mis-calculation of the relief holes made into the carpet at the drivers side location by the mfg...you can see the relief cut at the rear which is way outboard of the desired location and the same with forward but with the hole a little bit bigger...Interestingly enough there are body plugs at each location.......oooops!
