hmm...I may try that pump out regardless of my problem, always wanted to try out a vac pump.
Mr.P, what kind of vacuum should I look for if I am setting a relief valve? Too much is a bad thing in this case, correct?
It would depend on the pump.... on my dry sump I can
get 12"HG with just the pump so I dont run a vac pump
on it... if I were to use that I might set it at 5"
to 6"HG... because I would think (from what the others
are saying it might not like more) but I would have
to see what the pump can do
