I suck 3 or 4 oz. of oil on 8 passes with a breather may suck more if I cap it.The cool air gose in the motor it never blow the stick out again,keeps the water out.I drilled a hole and got that fitting from Star mach about $37 bucks toggle with 20amp. pump was about $27 ebay $8 for shippng.You won't want to run it all the time just running it.We do the burnout then turn it on.
