Yes Mr.Body...GM smog air pump used on '99 Corvette.Used them on a few alky motor cars to remove condensation from oil...a poor mans vacuum pump so to speak.Must be mounted in correct position to work best.Advance Auto part #32-2600M @ $95 w/warranty.
Any idea what the amp draw is on them... what size
fuse they run
