Thanks For the info I did it as well and it turned out perfect. I engine turned the shroud and then clear coated it.My fan is only 1/2 inch away from the edge of the opening and I haven't had any clearance problems.
Looks like someone has access to a TIG welder.
I like the engine turned finish. Works well with your engine compartment. It ran through my mind, but I went wrinkle to complement my other wrinkle stuff.
