Thanks Cass. I ended up just doing that anyhow, a little tight for press fit, but with CMP, it pressed in ok. He already had bought the studs, so I was trying to use what he had instead of making him buy more.
I'll check the email. I went and googled your site, then used the contact info link on there. Cant re-call the address, but I'll pull it back out of email in case something isnt working there.
Thanks.
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
