Something to consider, the pipe idea is ok if your running Green bearings but the OE tapered bearings need a spacer in the middle to force the axle out so the bearing cone seats in the race... At the very least you'll destroy the seals running it with just a pipe...
This is incorrect. the weight of the vehicle forces the axles out. Its a glorified front wheel bearing setup. The pipe deal is fine.
You might want to take another look at the design of Mopar axle bearings before posting that comment...
"The Armies of our ancestors were lucky, in that they were not trailed by a second army of pencil pushers."
