Fred, at your age...that will be the first of many diapers you will have to change....
Josh,you been hangin out at the other 2 sites too much Even you can be a dipstick once in a while
Fred,the material you purchased,is it fireproof??Is the ballistic material the "other guys " use fireproof?
I was waiting for you to calm down and come up with a solution for theses new rules with no rules
I do believe that the diaper should wrap around the outside of the oil lines where they enter the oil pan and come off the oil pump and only have a hole for the centerlink.I still have some expences that are in front of the diaper on the "LIST"
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
