I found it. A bonehead, rookie mistake. I have a Comp Cams crank sprocket with the "O" on the keyway as well as the timing mark. Guess which one I lined up with the cam sprocket...
I'm using the directions from Comp Cams, including a piston stop to find TDC. They're similar to other cam companies' directions, is this not the way to go?
Dude, your not the only one that has done that Check the lobe centers on both valves
