I found it. A bonehead, rookie mistake. I have a Comp Cams crank sprocket with the "O" on the keyway as well as the timing mark. Guess which one I lined up with the cam sprocket...
I'm using the directions from Comp Cams, including a piston stop to find TDC. They're similar to other cam companies' directions, is this not the way to go?
