Cheap China junk...
Internal passages too small, will make an engine run 20-30 degrees hotter...
Also the casting height is different from the OE Mopar aluminum one, forces one to use different spacers to get the proper fan belt/pulley alignment.
May work OK for a casual cruiser but dump it if one has built the motor and/or lives in a hot climate.
Just my $0.02...
