There has been some moaning about the size of one of the passages on the "drivers side inlet" castings. I just hogged that passage out on the one I have as there's plenty of material in that area - it took all of ten minutes to do. Otherwise the casting is nice and fits fine. For the price you really can't beat it.
Did the thermostat housing bolt spacing get corrected ?
Otherwise the OP really has no alternative choice if he wants something other than the stock iron housing .
