long ago there was an adapter made to fit a ford manual to it and i believe a chev automatic---find an 8 bolt hemi flywheel, bolt it on then put the 833 next to it to measure---i put an 833 to the back of a magnum V10 motor---used a getrag bellhousing and a 3/4" thick aluminum plate to bolt the 833 on--it works -and i would say if it runs use it even if our other pals dont like how it looks--i figure you arent going to be racing it so it will be existing as better visual alternative to a SBC---bob
