I personally like SRP pistons (213455). They come in right about .020 below deck.2.062 height. With a steel shim gasket your quench would be perfect at .040 and you wouldnt need to deck the block. http://www.jepistons.com/Catalogs/SRP/Mopar/400-440_flat.aspx
