Wiseco shows a 2.065 piston on page 41 that is what you want unless you decks are way under spec
http://www.wiseco.com/Catalogs/Automotive/CompleteCatalog.pdf
Chrysler 440 Flat Top
Kit Part # Bore Size Comp. Ht. Stroke Rod Lgth. Pin Dia. Dome
Volume
Comp. Ratio
88cc Head 78cc Head Cubic Inch Repl. Piston Repl. Ring
Part #
PT034H3 4.350”
2.050 3.750” 6.760” 1.094" -4cc 9.8:1 10.7:1 446 5034H3 4350H PT034H55 4.375” 9.9:1 10.7:1 451 5034H55 4375H
New! Chrysler 440 Flat Top • OEM & Indy Cyl. Heads
Volume
Comp. Ratio
Part #
PT137H3^ 4.350” 2.065 3.750” 6.760” .990" -6.3cc 9.6:1 10.4:1 446 5137H3 4350H
PT137H4^ 4.360” 9.6:1 10.5:1 448 5137H4 4360H
PT137H55^ 4.375” 9.7:1 10.6:1 451 5137H55 4375H
That may be what he NEEDS , but he WANTS the CHEAPY piston and ring package ...
