After looking at the one my buddy got it looks to me like it would work great if you have an aluminum oil pan with a nice flat surface such as the block is. I do agree it looks like it wont seal to good to a normal stock type pan. The stock pan needs a gasket that compresses a tad to fill in the pan rail. The problem with this is its hard plastic with the rubber seal made in it but that seal will not hit all the pan rail enough to me and will leak. If I had to use it I would put a small bead of the gray Mopar rtv sealer on both sides and hope it seals. Ron
