Here are some pictures of what I'm talking about. I just can't see how this is going to seal and this car CAN'T leak! I don't have the luxury of being a guinea pig.
You can see there are a couple areas where the gasket actually misses the pan completely. It would seal around the bolts pretty good. If they just made it fit a stock pan then it would probably fit pretty much anything.
And just for good measure here is the wiz bang Mancini rear main that doesn't work either. Side seals don't seal, retainer runs into the main cap AND the crank. It actually ground a bunch of aluminum off and packed it in the seal.
