So correct me if I'm wrong but in my 59* solid roller application I would need at least .550 offset rockers and offset lifter (most likely chebby oil fed lifters using the chrysler V bar)? Also remember my lifer bores are brushed so I'm not sure I need oil fed unless I just want the added insurance.
i dont think you want the offset lifters if you want it to live.
but you do want pushrod oiling since W9īs oil thru the lifters and pushrods.
