what about dome pistons say trw 2295's
You don't want anything that protrudes above deck when you run a closed chambered head like the stealths.
were do you come up with this crap?by coping old wrong info you did not find by doing. holmes the dome part goes under the open part of the chamber,of a closed chamber head. you will have more problems with eddy heads and dome pistons because of angle plugs. you have to grind/open up the plug relief in dome. here a pic of 440 i did 3 years ago with ross tall dome pistons and stealth heads, fit perfect. and Dear johnRR my 4340 billet hemi crank and big shinny stage v alum head is so massive your gunna need two hands to lift it,if you say i swallow anything honey
