Re: could someone decode my 440
[Re: DPelletier]
#1172814
02/06/12 06:19 PM
02/06/12 06:19 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
Or could have new lifters plated to oversize. I remember a Mopar Muscle article about a 340 block that had this problem, gave the builder fits.
R.
I had a block was not stamped oversize but the bores were out of whack and the geometry was way out , best and easiest way to correct was to bush the block .
What's the cost for that? I would have thought that unless it was a #'s block, it would be cheaper to start with a block that doesn't have any issues? Just curious.
I had no choice , it had a ton of other machine work already done, was lucky it only cost $750 considering where it was when it was found.
Just had it done to my current pure stock build 383 , cost about $500 , the plus is it caps off the free flow of oil past the lifters , more oil goes where it's supposed to go instead of just flooding the rotating assembly .
