Here is my situation. I am putting a 383/727 into my 1956 plymouth. It previously had a 361 in it with a powerflite transmission. The old starter was only 1 terminal up to the solenoid on the fenderwell and worked fine. I now have a mini starter in it with the 383/727 combo. The big wire is still there but it won't crank. I assume it is because I need to wire the usual small wire that comes from the starter as well. What exactly does that wire do and where can I put it. I am just afraid of frying the electrical system if I do it wrong. Thanks for any help.
