Hey Mr yuck you need good heads on a big block to go this fast and everyone in this post has had 440-1 heads. Last time I checked it was a good amount of money for a good set, cnc and rockers intake etc.. It ain't cheap going this fast weather its a big block or small block. I have a lot less in my motor then you think.
that's why I hit the "bargin bun" here on moparts when I break something. FWIW I think this stock stroke 440 w/ a larger solid roller, maybe more gear would run low 10's easy in an A-body.
Long way to go mid 9s from low 10s...and lots of money.
nothing a stroker kit, bigger stall and better intake/carb can't fix. low 10's are w/ the ported stage VI heads and factory 6 pack. But hey I'm happy w/ the way it runs. I drive it to the track and home (barring breakage) Should be close to 11.0's come spring.
