As a NSS racer I have to step in here with my observations. There is a NSS Class with rules with certain year and body styles permitted following the NMCA. It is my opinion that "if" you wanted to run an OUTLAW NSS class that the same rules apply for the year and body styles permitted but as an OUTLAW class open up the rules per tires, carbs intakes and whatever (dare I say n2o but whats the point). However with that said no one has said will this be a straight heads up class? Thats the only way to go because if it's on an index you would just have a 12 sec car with big tires run OUTLAW class and if it's a dial in then it's just another bracket race. Seems to be alot of interest in running NSS and if so build you car for the class instead of changing the current rules for a class to fit your car.
Carry on
Russ
