Quote: I am referencing that schematic too and it backs up my thinking of :
"" The MSD RED wire calls for the "original coil "+" terminal" wires. This would be the twin brown wires according to this schematic.""
It is the only combo that I have not tested yet.
Thanks guys.
In the diagram I posted you will see that the CRANK mode comes from the relay and the run comes from the switch... for MSD those 2 modes(crank and run) have to be tied together, other wise you wont have 12v during cranking
