Mine has a Jegs pad in the bottom the same pad as used in thier diaper. I had a serous coolant leak from the lower radiator hose. It had several quarts of coolant and was absorbed by the pad. I didn't realize how much coolant was there till I pulled the pan and emptied it out. It was contained
