I went with the GZ setup. Mostly because they answered the phone and talked me through all the parts I needed.
The price was OK and the kit showed up here real fast.
Mine's only pulling around 12 at the top end because I have it regulated down that much.
After experimenting a little I finally put the pickup in the driver side valve cover (Thank's Al) and put an extension on the top of the tank so the breather is well above the tank.
