Re: Educate me about vacuum pumps
[Re: jyrki]
#1127041
12/04/11 12:27 PM
12/04/11 12:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Going through friends 528 Wedge with CNC ported Indy heads. He bought it complete a couple of years ago from states, and it really hasn't performed according to expectations. I'll tear it a part and check it, and while at it he wants to install avacuum pump since the engine was designed to use one. What all is needed, and where to get the parts from? As far as I've understood,you aim at certain vacuum and limit it with aomekind of a leak retriction? Any good links or articles?l
There are a few companies that make a decent vac pump... Moroso makes 2 versions a 3 vane and 4 vane... I have a Aerospace unit and I dont care for it(doesnt pull enough)... with all the reading I did I found that you dont want to exceed 14"HG or you get into wrist pin oil issues... I pull 12"HG with just my dry sump pump.... what do you need... the pump, lines (I used braided lines), a good baffle in the valve cover and a puke tank to catch any oil that the pump pulls out(get a good one...get one that enters near the bottom... if it inters near the top it sprays oil/mist into the exiting air flow path and out the breather)... then the only other thing would be the check valve that would be mounted to the other valve cover... some are adjustable, some fixed for the setting.. back to the pump... Moroso says the 4 vane was race only and will pull more than 14", there is another good pump(forget the name but its Motorsport something) and they sell all the parts... also you need a drive system... crank pulley and belt.... some but not all of the pumps come with some sort of mounting.... thats about all I can think of
