Quote: I am pretty certain your Cuda would have had the additional ground strap. There will be no indication on your regular harness as this strap is entirely independent.
You could always just wire it up without the ground and see if the left side works (if in doubt)?
Everything works fine without the ground strap. thought all the lights were grounded to the the housings. when you pull a light socket out with lights on , the pulled light goes out.
