Quote: the trunk harness has a cloth type of wrapping, doesn't it? Not sure where you can get any of that. The wiring harness sold by Year One (made by M&H) is very good. Correct wiring, sockets and wrapping.
the original trunk wrapping is a cotton weave if I recall. I believe M & H can re-wrap your original harness if you call them directly.
The M&H repro harnesses are good reproductions, however the sockets are not 100% correct for OE. The side marker and two of the four tail lamp sockets differ from originals in appearance by quite a bit.
