Quote: was this ground wire on all cudas??? i have an early build 1970 and i restored the original wiring harness and never saw any wires routed to grounding the harness. no cuts or anything. very interesting info......
Ditto, the cuda I just finished had no signs of this ground wire( hamtrack built car btw)
I will say. The one I did, did not have these style nuts holding the lamp in
